Update to version 1.6 (Bookworm), 2.2 (Trixie) and the x86_64 port are already available
Posted: Sat Dec 13, 2025 10:18 pm
We’re pleased to announce that Hudiy version 1.6 (Bookworm), 2.2 (Trixie) and x86_64 port are now available. You can find the release highlights below:
Hudiy for x86_64
As of version 2.2, you can also install Hudiy on platforms based on the x86 64-bit architecture. The currently supported operating system for this architecture is Debian OS 64-bit Trixie with a graphical environment (Desktop) (e.g., Gnome or labwc).
Since Raspberry Pi OS is essentially a Debian port, all scripts and extensions should be easily transferable between these two systems. We have also managed to maintain full feature parity between the Hudiy versions for Raspberry Pi OS Trixie and Debian Trixie.
On the x86_64 platform, Hudiy uses VA-API for hardware acceleration to ensure the best possible user experience. Therefore, we recommend running Hudiy on platforms with VA-API support (which includes nearly all modern Intel CPUs). We also tested Hudiy on Intel N100 and N150 chips, which are a great alternative to the Raspberry Pi. All tests were successful.
We do not recommend and officially do not support running Hudiy on Virtual Machines (e.g., QEMU, VirtualBox, or VMWare). Virtual Machines do not provide sufficient hardware support for handling UI (OpenGL) and video rendering, and may also cause issues with PipeWire. However, we also ran Hudiy on virtual machines, and after a few configuration tweaks (depend on host machine), it is fully usable. This can serve as an alternative for more convenient extension development.
The x86_64 port is available free of charge under your current license. The Hudiy installation process is exactly the same as on the Raspberry Pi.
Additonal changes
Apart from the x86_64 port, we have introduced a few other changes described below.
Bluetooth
We added the ability to select the Bluetooth adapter used by Hudiy for pairing devices. This is useful when there is more than one Bluetooth adapter in the system.
Autobox
Based on your feedback, we have added the ability to manually set the video resolution for CarPlay projection with the AutoBox dongle. This is useful for controlling the size of elements on the CarPlay interface. However, since Hudiy does not support video transformation (e.g., stretching), it is up to the user to set a resolution that matches the screen’s aspect ratio to avoid letterboxing.
Android Auto
We improved D-pad emulation (map scrolling) and multitouch support for the latest labwc.
UI improvements
We also introduced a few minor interface changes so that the Hudiy UI scales better at lower resolutions.
Installing on x86_64
As mentioned before, the currently supported operating system for x86_64 is Debian Trixie 64-bit with Desktop.
To install Hudiy on x86_64 platforms, you need to re-download the installer. You can download it in the same way as before – the link to the installer from your confirmation order is still valid and now points to the new installer compatible also with Debian Trixie 64-bit for x86_64. It automatically detects which version of the Operating System and the architecture it’s running on and installs the appropriate version of Hudiy.
We have also updated the installation instructions for the latest Raspberry Pi Imager and x86_64. Except for the OS installation, the Hudiy installation process is identical on Raspberry Pi and x86_64.
Since version 1.6 requires updating Raspberry Pi OS Bookworm to the latest release, we recommend making a full system backup beforehand – just in case.
That way, you can easily revert to the previous state if any operating-system-level issues arise.
Before running the updater, if you’ve changed the system locale, please make sure the Character Set is set to UTF-8.
It seems that when changing the language, Raspberry Pi OS may set the character set to ISO, which can cause display issues and prevent programs (including the updater) from working correctly.
You can change the Character Set in: Start → Preferences → Raspberry Pi Configuration → Localisation tab → Locale → Character Set
Re: Update to version 1.6 (Bookworm), 2.2 (Trixie) and the x86_64 port are already available
Posted: Sat Dec 13, 2025 10:44 pm
by Moko
I'm testing this today on my i3 tablet with 4GB RAM and a 64GB SSD.
Posted: Wed Dec 17, 2025 1:02 am
Great job!! I'm going to get the Lattepanda IOTA with N150 processor for learning. I already designed and tested a custom PCB with 4 CAN ports, RS485, power timer controls for Pi. I'm now wondering how debian x86 works with those CAN utilities and hifiberry Digi2 card.
Is x86 Debian boot a lot faster within 20s?
Posted: Sat Dec 20, 2025 2:28 am
by Moko
Here's some feedback from testing the x86 version :
My specs: Intel Core i3
4 GB RAM
64 GB SSD
Freshly installed Debian Trixie
Generally speaking, and without going into Hudiy's features :
Booting isn't any faster than a Pi 4 with 1 GB of RAM !
The x86 architecture itself plays a significant role.
The interface is smoother on x86 (but I suppose it all depends on GPU performance) ! I'd say it's comparable to a Pi 5.
That's just my opinion !
The developer is doing their best to offer a product accessible to everyone, regardless of the platform.
Ultimately, everyone has their own specific needs.
PS: Hudiy doesn't need that much power if everything is well-structured and works in harmony ;)
I've been testing Hudiy for a few months now on a Raspberry Pi 4 with 1GB of RAM (temporarily) in
Full HD with HDMI display / CSI camera / SDR module and Android Auto running in Full HD
I have to say I was really surprised ! It remains smooth.
And the best part is that I'm not using any cooling for the Pi :lol: :lol:
Posted: Fri Jan 02, 2026 7:00 pm
by proteinklumpen
Hey,
I would like to patch hudiy. Currently I do have 1.0 on bookworm. If I use the updater, it throws this error:
sandro@hudiy:~/.hudiy/share $ ./updater
║   Hudiy Updater 1.0    ║
Welcome to the Hudiy Updater 1.0
This tool will automatically download and install updates for the Hudiy application.
An active internet connection is required during the update process.
In case of any errors or issues please contact us and provide output of the updater.
Checking preconditions
Checking for updates, current version: 1.0
Downloading index
Unable to access /tmp/hudiy/hudiy_updates.json
Running it as sudo gets me to this
sandro@hudiy:~/.hudiy/share $ sudo ./updater
Cannot open order file
So I thought I could trick it by doing this
sudo touch /tmp/hudiy/hudiy_updates.json
sudo chmod 777 /tmp/hudiy/hudiy_updates.json
Now I get to the following:
Downloading index
Downloaded: 640 bytes
Reading index
Searching for update package
Update to version 2.2 is available. Do you want to update? [y/n]:
I don't want hudiy 2.2, I am still on bookworm. How can I bring it to download 1.6?
Thanks in advance
Posted: Fri Jan 02, 2026 8:07 pm
The latest version is 2.2; however, the updater will automatically download the correct version for your operating system. If you are running Bookworm, version 1.6 will be downloaded. The message is indeed misleading and we will fix it in an upcoming release.
You do not need to run the installer or updater via sudo. Doing so may break file permissions and cause malfunctions. The install and update scripts will invoke sudo automatically when necessary.
This error is likely caused by running the updater with sudo previously. The easiest fix is to remove the file via sudo rm /tmp/hudiy/hudiy_updates.json and then re-run the updater without sudo.
More details about versioning are available in our blog post about 1.4/2.0 update:
https://hudiy.eu/version-1-4-available/
Posted: Sat Jan 03, 2026 2:07 pm
by proteinklumpen
Hey,
yes is was just a misleading message. It used the downloader an updated successfully to 1.6. Thanks for the help!
