Clean startup
Twardowsky29
Clean startup
Post by Twardowsky29 »
I have another question that neither I nor chatGPT knows the answer to: I it possible to make RPI do a clean startup? When I power it on I get cursor blink for a second and just a little bit of text before HUDIY loads and I tried removing it but without success. Let me know if there's any solution.
Re: Clean startup
Any kind of console cursor should disappear after adding vt.global_cursor_default=0 to /boot/firmware/cmdline.txt. This parameter is added automatically during the Hudiy installation.
Another parameter that should hide all text printed during startup is quiet which is included in cmdline.txt by default.
Could you please paste the contents of /boot/firmware/cmdline.txt?
Twardowsky29
Re: Clean startup
cmdline.txt:
console=tty1 root=PARTUUID=6a14ba1a-02 rootfstype=ext4 fsck.repair=yes rootwait  silent quiet splash loglevel=0 logo.nologo cfg80211.ieee80211_regdom=PL plymouth.ignore-serial-consoles vt.global_cursor_default=0
I've been fighting that cursor for a long time now... :)
Re: Clean startup
cmdline.txt looks good. These parameters should silence everything during Raspberry Pi OS boot. Could you take a photo of the exact cursor you mean?
Or do you perhaps mean diagnostic information printed by the firmware (before Linux starts)?
https://www.raspberrypi.com/documentati ... iagnostics
It can be disabled by editing eeprom config:
https://www.raspberrypi.com/documentati ... SABLE_HDMI
https://www.raspberrypi.com/documentati ... figuration
Twardowsky29
Re: Clean startup
Sure, here's the pic:
Re: Clean startup
Ah, so you mean the mouse cursor. The mouse cursor is managed by labwc, which is the default window compositor on Raspberry Pi OS.
There isn't a perfect way to hide the cursor in labwc (no simple config option), but starting from version 0.8.4 labwc includes a HideCursor action that can be bound to a keyboard shortcut or a windowRule.
As a workaround you can assign HideCursor and WarpCursor to keyboard shortcut in $HOME/.config/labwc/rc.xml like (take the touch node from your current config):
<?xml version="1.0"?>
<openbox_config xmlns="http://openbox.org/3.4/rc">
  <touch deviceName="WaveShare WS170120" mapToOutput="HDMI-A-1" mouseEmulation="no"/>
  <keyboard>
    <keybind key="A-W-h">
      <action name="HideCursor" />
      <action name="WarpCursor" x="-1" y="-1" />
    </keybind>
  </keyboard>
</openbox_config>
then using the wtype tool you can simulate defined key binding e. g. in /etc/xdg/labwc/autostart:
sudo apt install wtype
sudo nano /etc/xdg/labwc/autostart
/usr/bin/wtype -M alt -M logo h -m alt -m logo
/usr/bin/lwrespawn /usr/bin/pcmanfm-pi &
/usr/bin/lwrespawn /usr/bin/wf-panel-pi &
/usr/bin/kanshi &
/usr/bin/lxsession-xdg-autostart
More details about labwc configuration:
https://labwc.github.io/labwc-config.5.html
https://labwc.github.io/labwc-actions.5.html
Twardowsky29
Re: Clean startup
Okay, I managed to get it working, looks great now , thanks a lot.
