Android Auto not displaying correctly
Posted: Thu Aug 07, 2025 12:24 am
by Daflyinskwirl
Firstly, Hello and thank you for the new software! I had my setup running openautopro, but updated versions of Android Auto broke wireless connectivity, and I've been running wired since late last year. Wireless works perfectly with hudiy, so I am anxious to get it all setup. I know the community is still new, but I am wondering if someone can help with my issue:
I have a waveshare 9.3" wide screen. 1600x600 resolution. The same one as here:
https://www.amazon.com/dp/B0C462VKJ1?re ... in_title_1
My test setup uses a conventional 1920x1080 screen and while the resolution looked a bit low, it projected no problem and the touchpoints lined up.
My in-car setup however, uses the 9.3" display I posted above. The hudiy UI displays without issue, however when Android Auto launches, it is only in the center of the screen, and the touch points do not line up with the projected image.
I know it must be a configuration somewhere but I am not having much luck messing with the mainconfiguration.json file (Changed 480p to 600p and no change in the display).
Any help would be greatly appreciated. My programming skills are very limited, and I cannot find more technical documentation for Hudiy yet.
I should have checked the github first :geek: For anyone else with this issue, I believe I will find a solution on the below page:
Re: Android Auto not displaying correctly
Posted: Thu Aug 07, 2025 5:14 am
Hello, great to hear you found a solution. I’ll leave the link here in case someone else is looking for settings for a similar screen. viewtopic.php?t=7&start=10
If you have any other questions, feel free to ask here on the forum.
