Carplay nav
Posted: Fri Aug 01, 2025 5:55 pm
Another question apologies.
I was wondering if there’s any scope to make the nav widget take data from carplay? Does the carplay API expose the data. Thanks
Re: Carplay nav
Posted: Fri Aug 01, 2025 6:08 pm
Unfortunately, CarlinKit dongles do not expose those data. Only media metadata are available.
Re: Carplay nav
Posted: Sat Aug 02, 2025 3:23 pm
Thank you. Thats a shame that they dont.
Second question is about frame rate, it can be a bit choppy, is there any options for getting it to manage 60fps like autokit usually can?
Re: Carplay nav
Posted: Sat Aug 02, 2025 4:43 pm
Hudiy operates in auto-negotiation mode for resolution and frame rate with CarlinKit dongles, which is the safest option to ensure that CarPlay works reliably across screens of various sizes and resolutions. In most cases, the frame rate should be 60 FPS. Manually setting the resolution and frame rate may cause CarPlay to fail to start in certain scenarios.
Re: Carplay nav
Posted: Sat Aug 02, 2025 7:30 pm
Okay, thank you,
Mine definitely isnt, wired or wireless it’s not 60 for sure. Is there anything I can check on my side to see what could be upsetting it or causing a problem, ie my screen and sd card or peripherals.
Re: Carplay nav
Posted: Sat Aug 02, 2025 7:43 pm
Could you please let us know which screen you're using (ideally the exact model)? We’ll try to get the same one and test it in our environment.
Re: Carplay nav
Posted: Sun Aug 03, 2025 12:07 pm
Hey there,
Of course.
Ive been testing 2 waveshare screens;
https://www.waveshare.com/wiki/8HP-CAPLCD_Monitor
https://www.waveshare.com/wiki/8DP-CAPLCD
However my actual screen will be a customized version of this screen below and 8hp. Custom cover glass, and the LCD from 8HP, for high colour gamut. With a Dsi interface like 8DSI-C model. All exhibit poor frame rate.
https://www.waveshare.com/wiki/8inch_DSI_LCD_(C)
Let me know how you get on. They’re all pretty much the same screen just some differences in interface or brightness
Re: Carplay nav
Posted: Tue Aug 19, 2025 10:58 am
hi there had a thought how do i access the carlinkit settings, ones i’ve had before had a backend webpage accessible. i want to change the display name for the bluetooth and maybe the password for security
Re: Carplay nav
Posted: Wed Aug 20, 2025 12:25 pm
@hudiy admin, any help on this would be appreciated
Re: Carplay nav
Posted: Wed Aug 20, 2025 2:38 pm
On our dongles, the settings page is available at
http://192.168.43.1
It looks like in the Box Info section you can change the Bluetooth and WiFi names, but there’s no option to change the WiFi password.
