Page 3 of 3
Re: Keyboard volume control
Posted: Sun Jan 04, 2026 9:56 pm
by ioioio
hudiy wrote: Mon Sep 08, 2025 6:23 pm
If you already have a working script that communicates with Hudiy via the API, then you just need to call (depending on the signal you expect from the device):
def trigger_action(self, client, action):
dispatch_action = hudiy_api.DispatchAction()
dispatch_action.action = action
client.send(hudiy_api.MESSAGE_DISPATCH_ACTION, 0,
dispatch_action.SerializeToString())
self.trigger_action(client, "output_volume_up")
self.trigger_action(client, "output_volume_down")
self.trigger_action(client, "toggle_output_muted")
Just like in the example.
For your use case,
action can be:
- output_volume_up
- output_volume_down
- toggle_output_muted
https://github.com/wiboma/hudiy/blob/ma ... ed-actions
You can share your current script, and we’ll try to modify/refactor it if you’d like.
Hallo would you mind provide a simple example (full working python file) that will trigger a volume change, something as basic as possible, as I do not seem to be able to get started, thanks
Posted: Mon Jan 05, 2026 5:09 pm
To control the volume, you need to use the DispatchAction message from the API and dispatch output_volume_up/output_volume_down actions.
Docs for DispatchAction:
https://github.com/wiboma/hudiy/blob/ma ... proto#L723
List of predefined actions:
This script dispatches output_volume_up/output_volume_down every 5 seconds. Just checkout the Hudiy repo and save below code to e. g. Volume.py file in
https://github.com/wiboma/hudiy/tree/ma ... api/python directory.
You need to install python3-protobuf and python3-websocket dependencies to use the API (
sudo apt install -y python3-protobuf python3-websocket)
# Copyright (C) Hudiy Project - All Rights Reserved
import threading
class EventHandler(ClientEventHandler):
def __init__(self):
self._volume_up = False
self._timer = None
def on_hello_response(self, client, message):
print(
"received hello response, result: {}, app version: {}.{}, api version: {}.{}"
.format(message.result, message.app_version.major,
message.app_version.minor, message.api_version.major,
message.api_version.minor))
self.control_volume(client)
def control_volume(self, client):
self._volume_up = not self._volume_up
dispatch_action.action = "output_volume_up" if self._volume_up else "output_volume_down"
self._timer = threading.Timer(5, self.control_volume, [client])
self._timer.start()
def get_timer(self):
return self._timer
def main():
client = Client("Volume")
event_handler = EventHandler()
client.set_event_handler(event_handler)
client.connect('127.0.0.1', 44405)
active = True
while active:
try:
active = client.wait_for_message()
except KeyboardInterrupt:
break
if event_handler.get_timer() is not None:
event_handler.get_timer().cancel()
client.disconnect()
if __name__ == "__main__":
main()
Posted: Tue Jan 06, 2026 4:18 pm
by ioioio
Thank you, I moved this part of the thread to the programming section
viewtopic.php?t=170 in case somebody is interested
