Page 2 of 3
Re: Bad colour banding in carplay
Posted: Sun Oct 26, 2025 11:33 am
Okay, thanks for the helpful insight.
Nevertheless it’s not ideal, I will submit a report to apple.
Could you test in your end to see if it’s affected.
Posted: Mon Oct 27, 2025 2:00 pm
Please let me know if you can see if it’s just mine or if it occurs on yours
Thanks
Posted: Thu Oct 30, 2025 1:49 am
by ltlnmo
I also notice that the blacks seem very very black and the colors are very very saturated when comparing to my same Carplay setup on Lineage OS (Android). Any fix?
Posted: Thu Oct 30, 2025 1:50 am
by ltlnmo
I also noticed that Carplay on Hudiy the blacks are very very black and the colors are very very saturated/vivid when compared to the same Carplay setup on Lineage OS (android)
Posted: Thu Oct 30, 2025 4:01 am
Yeah, this for sure needs investigation
Posted: Thu Oct 30, 2025 6:39 am
ltlnmo wrote: Thu Oct 30, 2025 1:50 am
That might be related to the colorimetry. The most common colorimetry in Raspberry Pi OS is BT.709. For resolution <480p as far as we know the BT.601 might be selected by the decoder/GPU driver (kernel). Is your screen detected the same way on Raspberry Pi OS and Android?
Posted: Thu Oct 30, 2025 11:23 am
But we have seen it still shows up on other devices when screenshotted?
Posted: Tue Nov 04, 2025 10:20 am
Any chance you could test this? Been waiting for a reply. Would be much appreciated:)
Posted: Sun Nov 09, 2025 11:35 pm
We found a possible issue. On some displays, Raspberry Pi OS forces a 16-bit color depth for OpenGL surfaces, which can indeed cause color banding. We managed to find a screen where we were able to reproduce the problem you're likely describing. We'll include a fix in the upcoming release.
Wrong bit depth:
Correct bit depth:
Posted: Mon Nov 10, 2025 11:27 am
hi there,
thanks for this. when can i expect a fix? is there something i can do in the meantime that will help? as i cant use it like this frustratingly.
also small observation that, interestingly there is different scaling across these two images. how do i get the smaller scaling rather than the first image where its massive. are these two screenshots from the same screen.
thanks for solving this it was getting very annoying!
