Re: Keyboard volume control
Posted: Thu Aug 07, 2025 5:47 pm
Does this mean if i’m making a script to decode the canbus buttons via car pi hat, i can’t map it to the keyboard inputs. and im limited to the api actions? thank you
Unfortunately, Wayland is very limited when it comes to keyboard emulation due to security reasons.alex124.rh wrote: Thu Aug 07, 2025 5:47 pm Does this mean if i’m making a script to decode the canbus buttons via car pi hat, i can’t map it to the keyboard inputs. and im limited to the api actions? thank you
def trigger_action(self, client, action):
dispatch_action = hudiy_api.DispatchAction()
dispatch_action.action = action
client.send(hudiy_api.MESSAGE_DISPATCH_ACTION, 0,
dispatch_action.SerializeToString())
self.trigger_action(client, "output_volume_up")
self.trigger_action(client, "output_volume_down")
self.trigger_action(client, "toggle_output_muted")
import smbus
from pynput.keyboard import Key, Controller
import lgpio
import time
import os
import threading
# I2C constants
I2C_BUS = 1
I2C_ADDRESS = 0x08
# Messages
ALIVE_MSG = 0x4C # Pi -> Teensy
COUNTDOWN_MSG = 0x43 # Pi -> Teensy (countdown active)
SHUTDOWN_REQ = 0x3B # Teensy -> Pi (shutdown request)
SHUTDOWN_ACK = 0x53 # Pi -> Teensy
SHUTTING_DOWN = 0x44 # Pi -> Teensy ("going down")
# Key control signals
NO_KEY = 0x00
HARDBOOT_SIGNAL = 0x52
MCU_RESET_SIGNAL = 0x54
GPIO13 = 13
# HDMI control
HDMI_OFF_DELAY = 10 # seconds before HDMI goes off in countdown
# Key mappings
KEYS = {
0x00: None,
0xCC: Key.f11, # Mute key
0xC9: Key.f8, # VolCW
0xC8: Key.f7, # VolCCW
0xDA: Key.up,
0xD9: Key.down,
0xD8: Key.left,
0xD7: Key.right,
0xB0: Key.enter,
0xB1: Key.esc,
0x48: 'H',
0x4A: 'J',
0x46: 'F',
0xC4: Key.f3, # Fav (with Ctrl pressed)
0x31: '1',
0x32: '2',
0x52: 'R',
0x54: 'T',
0x4C: 'L',
0x4D: 'M',
0x70: 'P',
0x6F: 'O',
0x6E: 'N',
0x76: 'V',
# Globals
keyboard = Controller()
bus = smbus.SMBus(I2C_BUS)
# GPIO setup (lgpio)
CHIP = 0
chip = lgpio.gpiochip_open(CHIP)
lgpio.gpio_claim_output(chip, GPIO13)
lgpio.gpio_write(chip, GPIO13, 1) # set HIGH initially
running = True
shutdown_initiated = False
in_countdown = False
# HDMI state
hdmi_active = True
hdmi_timer = 0
hdmi_lock = threading.Lock()
# Helpers
def press_key_with_delay(key, delay=0.05):
keyboard.press(key)
time.sleep(delay)
keyboard.release(key)
def execute_keystroke(key_code):
key = KEYS.get(key_code)
if key is None:
return
if key_code == 0xC4: # Ctrl + F3
with keyboard.pressed(Key.ctrl):
press_key_with_delay(Key.f3)
elif isinstance(key, Key):
press_key_with_delay(key)
elif isinstance(key, str):
keyboard.type(key)
# HDMI Control (Bookworm / Pi 5)
def hdmi_on():
global hdmi_active
with hdmi_lock:
if not hdmi_active:
print("[HDMI] Screen will restore on keypress")
hdmi_active = True
def hdmi_off():
global hdmi_active
with hdmi_lock:
if hdmi_active:
print("[HDMI] Blanking screen (any key will restore)")
os.system("kmsblank")
hdmi_active = False
def hdmi_countdown_worker():
global hdmi_timer
while running:
if in_countdown:
if hdmi_timer > 0:
print(f"[HDMI] Countdown: {hdmi_timer}s")
time.sleep(1)
hdmi_timer -= 1
elif hdmi_active:
hdmi_off()
time.sleep(1)
else:
time.sleep(1)
# Key / Control handling
def process_key_event(key_byte):
if key_byte == HARDBOOT_SIGNAL:
print("[Pi] Hardboot signal received, rebooting.")
os.system("sudo reboot")
elif key_byte == MCU_RESET_SIGNAL:
print("[Pi] MCU reset signal received, toggling GPIO13.")
lgpio.gpio_write(chip, GPIO13, 0)
time.sleep(0.2)
else:
print(f"[Pi] Key Received: {hex(key_byte)}")
execute_keystroke(key_byte)
# Heartbeat Task
def heartbeat_task():
global running, shutdown_initiated, in_countdown
while running and not shutdown_initiated:
try:
if in_countdown:
bus.write_byte(I2C_ADDRESS, COUNTDOWN_MSG)
print("[Pi] Sent COUNTDOWN (still alive, preparing).")
else:
bus.write_byte(I2C_ADDRESS, ALIVE_MSG)
print("[Pi] Sent ALIVE.")
except Exception as e:
print(f"[Pi] I2C write error: {e}")
time.sleep(5)
# Listen for Teensy messages
def listen_for_teensy():
global shutdown_initiated, in_countdown, hdmi_timer
try:
msg = bus.read_byte(I2C_ADDRESS)
if msg == SHUTDOWN_REQ:
print("[Pi] Teensy requested shutdown.")
try:
bus.write_byte(I2C_ADDRESS, SHUTDOWN_ACK)
print("[Pi] Sent SHUTDOWN ACK to Teensy.")
print(f"[Pi] I2C write error (ACK): {e}")
try:
bus.write_byte(I2C_ADDRESS, SHUTTING_DOWN)
print("[Pi] Sent SHUTTING DOWN signal.")
print(f"[Pi] I2C write error (shutdown msg): {e}")
shutdown_initiated = True
print("[Pi] Executing shutdown now.")
os.system("sudo shutdown now")
elif msg == COUNTDOWN_MSG:
if not in_countdown:
print("[Pi] Teensy entered COUNTDOWN mode.")
hdmi_timer = HDMI_OFF_DELAY
in_countdown = True
elif msg == NO_KEY:
if in_countdown:
print("[Pi] Countdown cancelled, back to ALIVE mode.")
hdmi_on()
else:
process_key_event(msg)
except Exception:
time.sleep(1)
# Main
if __name__ == "__main__":
t1 = threading.Thread(target=heartbeat_task, daemon=True)
t2 = threading.Thread(target=listen_for_teensy, daemon=True)
t3 = threading.Thread(target=hdmi_countdown_worker, daemon=True)
t1.start()
t2.start()
t3.start()
try:
while True:
time.sleep(1)
except KeyboardInterrupt:
running = False
print("[Pi] Stopped by user.")
finally:
# Cleanup GPIO
lgpio.gpiochip_close(chip)
Keyboard Emulation with latest Raspberry Pi OS 64 Bit (bookworm) on my Raspberry Pi 4B 4GB with python-uinput 1.0.1 in my pyrhon3 script is working finehudiy wrote: Thu Aug 07, 2025 3:13 pmOn Wayland (the default window system in Bookworm), keyboard emulation is very limited.wkl3968 wrote: Thu Aug 07, 2025 2:39 pm basically I have decoded the LIN BUS from the car controller and I',m using an arduino to emulate like a USB keyboard. is there a keyboard key stroke for commanding the hudiy like OpenAuto Pro? How would should I approach this?
Compared to X11, there’s no straightforward way to achieve this.
The best approach would be to move your LIN BUS decoder program to the Raspberry Pi and use the API to send the appropriate commands to Hudiy.
Alternatively, you could send the decoded signals from the Arduino to the Raspberry Pi via the serial port.
Then, on the Raspberry Pi, you could read these signals from the serial interface and map them to the appropriate actions using the Hudiy API.
async def import_uinput():
global events, device, uinput
try:
events = (
uinput.KEY_1, uinput.KEY_2, uinput.KEY_UP, uinput.KEY_DOWN, uinput.KEY_LEFT, uinput.KEY_RIGHT,
uinput.KEY_ENTER, uinput.KEY_ESC, uinput.KEY_F2, uinput.KEY_B, uinput.KEY_N, uinput.KEY_V,
uinput.KEY_F12, uinput.KEY_M, uinput.KEY_X, uinput.KEY_C, uinput.KEY_LEFTCTRL, uinput.KEY_H, uinput.KEY_T
device = uinput.Device(events)
elif msg == '373004000200' and back > 0: # RNS-E: return button released
if back <= 4:
device.emit(uinput.KEY_ESC, 1)
device.emit(uinput.KEY_ESC, 0)
back = 0
