Thank you for your research. In our country, the Orange Pi is currently quite hard to come by, but it's good to have an idea of the state of hardware support in the Linux kernel and Debian in general.
This kind of CPU usage indicates that the video is likely being decoded by a software decoder. If you send us the hudiy logs (the $HOME/.hudiy/log directory), we can check what's going on with the video layer in Hudiy - whether the kernel is properly detecting the hardware video decoders.RockyHarder22 wrote: Mon Sep 14, 2026 5:58 amOn both of these, with heatsinks and active cooling the tempeature really never gets above 50. CPUs are working hardest when Android Auto is active and FM radio is playing, and they average about 50% at that point. for AA the setting I'm using are 720p / 30 fps. 1080p crashes it. 720 /60 fps works, with CPU popping up to 55-65. With 720/60 AA displayed while fm radio is playing the CPU are jumping up into 70-90% territory but temp is stable at about 45 degrees.
