Page 2 of 2
Re: Trixie/ DAC (CarPiHAT Pro)
Posted: Mon Mar 09, 2026 7:55 pm
Sambolini94 wrote: Sat Mar 07, 2026 1:58 pm A follow up to this, I've seen it briefly mentioned though sometimes when I boot the pi it all loads fine and if I have my autobox plugged in will auto play media but the volume is either a decent loudness or quieter... is there a way to set a consistent volume level or max volume output for best control?
Did you observe any differences in the volume levels in the output of pactl list sinks and pactl list sink-inputs when the issue occurs? Are there any differences in the audio routing? Restoring the volume level of the sinks is the responsibility of the PipeWire/WirePlumber. You can set the desired volume level using pactl set-sink-volume xx% command but anyway it should be handled automatically by the WirePlumber. Hudiy lowers the volume level only during playback of the navigation guidance (ducking).
Posted: Sat Mar 14, 2026 6:22 pm
by Sambolini94
I've been keeping an eye on pactl list sinks and it would appear the sink is set to 100% correctly and then when i run Hudiy again and start carplay/navigation it ducks the volume to 40% and doesn't reset to 100% for some reason... is there a way to force with reboots the sink always sets to 100%?
Posted: Sat Mar 14, 2026 7:05 pm
Hudiy applies ducking by modifying the sink input (stream) volume, not the entire sink volume. Could you please post the outputs of pactl list sinks, pactl list sink-inputs and pactl get-default-sink commands before Hudiy startup, after Hudiy startup and when CarPlay navigation is started?
