Page 2 of 2
Re: Installing on x86?
Posted: Sat Mar 07, 2026 4:29 am
by viseme
I see, I understand why the video engine usage is low.
I moved libgstva.so and disabled useX86Drm, but it seems vaapi is still being used. I've attached the log.
The display is just a regular FullHD 60Hz monitor. Thank you.
Posted: Sat Mar 07, 2026 8:07 am
Yes, because your GStreamer has alternative VAAPI codecs. Please also move file sudo mv /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvaapi.so /home/viseme and check how the projection behaves with no VAAPI codecs.
Was 60Hz correctly detected by the system (e. g. in Display settings)? Is there any scaling active?
Posted: Mon Mar 09, 2026 2:13 pm
by viseme
The projection is now smooth after disabling VA-API (by removing libgstva.so and libgstvaapi.so).
Video Engine: 0% usage.
Render/3D Engine: Increased to ~60%.
GPU Clock: Jumped from 200MHz to 715MHz.
It appears that on Geminilake, the light VA-API workload was keeping the GPU in a low-power state (RC6), causing the delay. Forcing the Render engine has effectively "woken up" the GPU frequency.
On the other hand, I am trying to increase the GPU clock speed with vaapi, but it is not working. I disabled C-State in the WYSE5070 BIOS, changed powercontrol to on and added kernel options.
Posted: Thu Apr 02, 2026 9:13 am
Any improvement in boot time, interfacing speed with x86 system? I'm thinking of getting Lattepanda IOTA for Hudiy which has higher speed than Pi5.
