having some big issues currently getting my DAC to work nicely with hudiy
been reading through the forums trying to get an idea of what might be the issue, but it seems to be that hudiy cant pick the correct input
this is the current bootup config that is not working
i've confirmed if I set the hudiy_equalizer_sink output to Built-in Audio Pro, that it plays fine and also has volume control, but I am not sure if that is the correct way to do it, and also on reboot it just re-configures back to not working
what can I do to get it to detect the correct output?
Innomaker Raspberry Pi HiFi DAC Mini HAT
Re: Innomaker Raspberry Pi HiFi DAC Mini HAT
pactl list sinks
Sink #64
State: RUNNING
Description: Built-in Audio Pro
Sample Specification: s32le 2ch 48000Hz
Channel Map: aux0,aux1
Volume: aux0: 65536 / 100% / 0.00 dB, aux1: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.platform-soc_107c000000_sound.pro-output-0.monitor
Flags: HARDWARE DECIBEL_VOLUME LATENCY
alsa.card = "0"
alsa.card_name = "BossDAC"
alsa.class = "generic"
alsa.device = "0"
alsa.driver_name = "snd_soc_allo_boss_dac"
alsa.id = "Boss DAC HiFi [Master] pcm512x-hifi-0"
alsa.long_card_name = "BossDAC"
alsa.name = "Boss DAC HiFi [Master] pcm512x-hifi-0"
alsa.resolution_bits = "32"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
api.alsa.card.longname = "BossDAC"
api.alsa.card.name = "BossDAC"
api.alsa.path = "hw:0,0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "AUX0,AUX1"
card.profile.device = "0"
clock.name = "api.alsa.0"
device.api = "alsa"
device.class = "sound"
device.id = "59"
device.profile.description = "Pro"
device.profile.name = "pro-output-0"
device.profile.pro = "true"
device.routes = "0"
factory.name = "api.alsa.pcm.sink"
device.description = "Built-in Audio"
node.name = "alsa_output.platform-soc_107c000000_sound.pro-output-0"
node.nick = "Boss DAC HiFi [Master] pcm512x-hifi-0"
object.path = "alsa:acp:BossDAC:0:playback"
port.group = "playback"
priority.driver = "1000"
priority.session = "1000"
factory.id = "19"
client.id = "36"
object.id = "64"
object.serial = "64"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
api.acp.auto-port = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
device.bus_path = "platform-soc@107c000000:sound"
device.enum.api = "udev"
device.form_factor = "internal"
device.icon_name = "audio-card-analog"
device.name = "alsa_card.platform-soc_107c000000_sound"
device.nick = "BossDAC"
device.plugged.usec = "3506954"
device.subsystem = "sound"
sysfs.path = "/devices/platform/soc@107c000000/soc@107c000000:sound/sound/card0"
device.string = "0"
Formats:
pcm
Sink #80
State: RUNNING
Description: hudiy_equalizer_sink Sink
Sample Specification: float32le 2ch 48000Hz
Owner Module: 536870916
Volume: front-left: 29491 / 45% / -20.81 dB, front-right: 29491 / 45% / -20.81 dB
Monitor Source: hudiy_equalizer_sink.monitor
Flags: DECIBEL_VOLUME LATENCY
node.name = "hudiy_equalizer_sink"
device.class = "filter"
audio.position = "[ FL, FR ]"
node.group = "ladspa-sink-536870916"
pulse.module.id = "536870916"
device.description = "hudiy_equalizer_sink Sink"
node.link-group = "filter-chain-880-13"
node.virtual = "true"
resample.prefill = "true"
resample.disable = "true"
media.name = "hudiy_equalizer_sink Sink input"
stream.is-live = "true"
node.want-driver = "true"
node.autoconnect = "true"
adapt.follower.spa-node = ""
object.register = "false"
factory.id = "7"
client.id = "68"
object.id = "69"
object.serial = "80"
node.driver-id = "64"
Formats:
pcm
Sink #95
State: RUNNING
Description: Echo-Cancel Sink
Owner Module: 536870917
Volume: front-left: 32768 / 50% / -18.06 dB, front-right: 32768 / 50% / -18.06 dB
Monitor Source: echo_cancel_sink.monitor
node.name = "echo_cancel_sink"
pulse.module.id = "536870917"
device.description = "Echo-Cancel Sink"
node.group = "echo-cancel-880-14"
node.link-group = "echo-cancel-880-14"
node.latency = "480/48000"
media.name = "Echo-Cancel Sink"
factory.id = "7"
client.id = "79"
object.id = "81"
object.serial = "95"
Formats:
pcmRe: Innomaker Raspberry Pi HiFi DAC Mini HAT
Audio stack in Raspberry Pi OS is handled by PipeWire and WirePlumber. Once the routing is configured, WirePlumber is responsible for restoring it after a restart and applying the last used volume levels.
hudiy_equalizer_sink and echo_cancel sink are PipeWire modules that are loaded from $HOME/.hudiy/share/hudiy_startup.sh
You can try setting master directly as your DAC and see if WirePlumber will be able to restore the routing after a restart. Please modify the hudiy_startup.sh as below and check what is the behavior
You can also check the PipeWire and WirePlumber GitLab pages to see if similar issues with your DAC have been reported:
https://gitlab.freedesktop.org/pipewire ... /-/issues/
sink_exists "$EC_SINK" || pactl load-module module-echo-cancel aec_method=webrtc aec_args=\"voice_detection=false\" source_name="$EC_SOURCE" sink_name="$EC_SINK" sink_master=alsa_output.platform-soc_107c000000_sound.pro-output-0
confirmed working- I had to remove master="$EC_SINK" and add master_sink but that worked!
thank you!
thank you!
