Applications menu (Web; Games; Power): YouTube, Google; Games; Shutdown, Reboot, Return
Autyzmiasty
Re: Applications menu (Web; Games; Power): YouTube, Google; Games; Shutdown, Reboot, Return
Hi i got a problem with this - if i exit hudiy to rpi bookworm os and in terminal paste 127.0.0.1:44480/google it's working but in hudiy first i had red shoutmarks *my eng is poor*. But finally it start running in hudiy but no internet connection :/. When in bookworm it's working fine shutdown, restart, return, and games works perfectly fine
Autyzmiasty
Could you describe how you solved this problem? My problem is likely an issue with my phone, but I have been unable to get mobile internet connectivity working with either wireless or wired android auto. I can't USB tether as the AA connection break the tether (both for wired and wireless AA). I also can't get AA to work by having both the RPi and my phone connected to the same WiFi network. At this point the only option I can think of is to plug a USB hotspot into the Pi, but I'd rather not have to eat that expense if I don't have to.
Goodevening,
Thanks for your hard work.
I seem to have a problem with the py file i dont have the servive file in etc systemd sytem...
What my problem is that the buttons shows but when i press i get a red window with a stop sign in my screen.
I think the py file dont start.
I now have both files in a document folder and i managed to put in the right path for my py file but i dont know what i am doing wrong right now.
To create a .service file, change into direcotry of system: "cd /etc/systemd/system/" and then "sudo nano hudiy_server.service" and then insert the code inside.:
_____________________________________
[Unit]
Description=Hudiy Flask server for system actions
After=network.target
[Service]
ExecStart=/usr/bin/python3 /home/path/to/your/hudiy_server.py
User=pi #choose your user
Restart=always
[Install]
WantedBy=multi-user.target
_______________________________________
! Take in mind here, to change the path in "ExecStart=/usr/bin/python3 /home/path/to/your/hudiy_server.py". to e.g.:
"ExecStart=/usr/bin/python3 /home/pi/Document/hudiy_server.py".
! Also there is a "User=pi", if you are logged in as someone else, then change the user corresponding to yours, e.g.: "User=Leeuw_12".
Then use "sudo systemctl daemon-reload", "sudo systemctl enable hudiy_server.service" &
"sudo systemctl start hudiy_server.service".
You can check out, if the service is working.: "sudo systemctl status hudiy_server.service". And you should see, it is active or in the case of failure -dead.
Addiotionaly, if you are sure, the service is right but the "hudiy_server.py" doesnt start. You can change into directory were the "hudiy_server.py" is stored, e.g.: "cd /home/pi/Document" and then run "python3 hudiy_server.py". You should see in the terminal the errors that could case a problem.
Hope this helps.
[Unit]
[Service]
Restart=always
[Install]
Hope this helps.
Good evening,
So i manached to get it started, i am a bit noob in this...
I can now shut down or reboot no problem. But with web still i get a red screen with a stop sign.
I was thinking how do i connect to the internet ?
I have android auto wireless set up. So i think maybe this is my problem. But i cant find where i can connect to internet ?
Sorry bit noob but maybe you can help again.
Hi Leeuw_12,
I never had in the car till today. I think I will have to see how to forward the internet from phone to the raspberry pi. I always had Hudiy setup on the desk while connected directly to the internet.
If I will find a solution, I will let you know.
So i was going trough all the files. When i open hudiy_py file i dont see any command for going to youtube. But maybe this isnt needed?? Because its not local ? But i dont know.
Youtube and Google are locaten in applications.json and applications_menu.json
In applications.json - he is defined action - open youtube, which opnes the url: https://youtube.com
"applications": [
"action": "open_youtube",
"url": "https://youtube.com",
"allowBackground": true,
"controlAudioFocus": true,
"audioStreamCategory": "ENTERTAINMENT"
In applications_menu.json - here is defined what you see in the menu in Hudiy. A new created section "Web" and in this section is "Google" and "Youtube". When you click on "Youtube" it calls the action - open youtube. Based on the action defined in applications.json, it knows what it should do.
"categories": [
"Web"
"iconName": "youtube_searched_for",
"label": "YouTube"
"applications": [
"categories": [
"Web"
"label": "YouTube"
Yeah, i saw all this files.. they are right....
Thats why i think there must be something wrong with internet or so. When i click it just pop up with red stopscreen
