Autobox upscale
Autobox upscale
Is it possible to upscale for auto box too? to get a higher resolution and thus have smaller ui scaling
Re: Autobox upscale
alex124.rh wrote: Sat Sep 27, 2025 6:18 am Is it possible to upscale for auto box too? to get a higher resolution and thus have smaller ui scaling
Autobox devices do not have such configuration options. You can set resolution only and UI is scaled automatically by the device.
Re: Autobox upscale
But could i set a higher resolution so that the device might scale it differently based on the higher res. thanks. my screen is 1280x800
Re: Autobox upscale
The same resolution is also used for touch events. Setting it bigger than the screen size could result with inacurate touch handling.
In the latest CarPlay there is something called Smart Display Zoom. You can try it to scale the interface https://9to5mac.com/2025/09/22/carplay- ... play-zoom/
Re: Autobox upscale
could i try it if i scale it correctly? thanks
Re: Autobox upscale
alex124.rh wrote: Sat Sep 27, 2025 2:19 pm could i try it if i scale it correctly? thanks
We will look into the possibility of adding configuration options for setting a custom resolution. If testing goes well, we'll include this in the next version of Hudiy.
Re: Autobox upscale
Thanks sounds good
