We are happy to announce that Hudiy 1.24/2.20 is now available. You can find the release highlights below:
Audio Focus
We improved volume ducking smoothness (navigation guidance and notifications) in audio focus.
Android Auto
We improved connection stability for the latest version of Android Auto.
Update to version 1.24 (Bookworm) and 2.20 (Trixie) is already available
Re: Update to version 1.24 (Bookworm) and 2.20 (Trixie) is already available
The boot seems very classic where we are still getting some flashes of Debian desktop screen. Is there plans to to remove those flashes and make it seem less like splash then Hudiy UI? No flashes of other background graphic.
Please check the solution from this post viewtopic.php?p=491#p491wkl3968 wrote: Fri Aug 07, 2026 4:49 am The boot seems very classic where we are still getting some flashes of Debian desktop screen. Is there plans to to remove those flashes and make it seem less like splash then Hudiy UI? No flashes of other background graphic.
I'm trying to detect the Android Auto navigation audio start and end so that I can channel the audio to specific channels. How can I do this? So far navigation audio is mixed with media playback and hence I cannot detect it. I can detect the Google assistant. Need some guidance here
Any new updates coming?
Yes, the update will be released later this month. We are working on improvements to H.264 hardware decoding and color settings for different types of screens:
viewtopic.php?t=311
viewtopic.php?t=346
Changes are currently under testing.
We are also working on an example of DTC handling via ELM327.
Nice! I've been thinking of trying to vibe code DTC reading and deleting as I drive an old Subaru which is well known of having frequent P0420 error and disabling cruise control. Your example would really help me to starthudiy wrote: Sat Sep 05, 2026 10:21 amYes, the update will be released later this month. We are working on improvements to H.264 hardware decoding and color settings for different types of screens:
viewtopic.php?t=311
viewtopic.php?t=346
Do you plan to add brightness control mentioned in t-346?
Also I still experience audio focus issues on Raspberry 4B connected to car audio over Bluetooth ad using Pixel 9 with Android 17. Did you get get any reports about this on v2.20?
In the latest version, it will be possible to adjust the colors, gamma and contrast in rendering post-processing. This will allow the image to better match the display panel.eingeryn wrote: Fri Sep 11, 2026 6:13 pm Nice! I've been thinking of trying to vibe code DTC reading and deleting as I drive an old Subaru which is well known of having frequent P0420 error and disabling cruise control. Your example would really help me to start
What exact issue with audio focus are you experiencing in your setup? If you describe the problem and your setup in detail, we can try to reproduce the issue on our end.
I've been checking daily since you posted this, I'm excited to see the DTC example.hudiy wrote: Sat Sep 05, 2026 10:21 amYes, the update will be released later this month. We are working on improvements to H.264 hardware decoding and color settings for different types of screens:
viewtopic.php?t=311
viewtopic.php?t=346
I'm waiting too. Is there a function to change the background color from brown to other colors? I like it black or some gradient or something else
