Update to version 1.24 (Bookworm) and 2.20 (Trixie) is already available
We are happy to announce that Hudiy 1.24/2.20 is now available. You can find the release highlights below:
Audio Focus
We improved volume ducking smoothness (navigation guidance and notifications) in audio focus.
Android Auto
We improved connection stability for the latest version of Android Auto.
Re: Update to version 1.24 (Bookworm) and 2.20 (Trixie) is already available
The boot seems very classic where we are still getting some flashes of Debian desktop screen. Is there plans to to remove those flashes and make it seem less like splash then Hudiy UI? No flashes of other background graphic.
wkl3968 wrote: Fri Aug 07, 2026 4:49 am The boot seems very classic where we are still getting some flashes of Debian desktop screen. Is there plans to to remove those flashes and make it seem less like splash then Hudiy UI? No flashes of other background graphic.
Please check the solution from this post viewtopic.php?p=491#p491
I'm trying to detect the Android Auto navigation audio start and end so that I can channel the audio to specific channels. How can I do this? So far navigation audio is mixed with media playback and hence I cannot detect it. I can detect the Google assistant. Need some guidance here
Any new updates coming?
wkl3968 wrote: Tue Sep 01, 2026 3:44 am Any new updates coming?
Yes, the update will be released later this month. We are working on improvements to H.264 hardware decoding and color settings for different types of screens:
viewtopic.php?t=311
viewtopic.php?t=346
Changes are currently under testing.
We are also working on an example of DTC handling via ELM327.
eingeryn
Post by eingeryn »
hudiy wrote: Sat Sep 05, 2026 10:21 am
viewtopic.php?t=311
viewtopic.php?t=346
Nice! I've been thinking of trying to vibe code DTC reading and deleting as I drive an old Subaru which is well known of having frequent P0420 error and disabling cruise control. Your example would really help me to start :D
Do you plan to add brightness control mentioned in t-346?
Also I still experience audio focus issues on Raspberry 4B connected to car audio over Bluetooth ad using Pixel 9 with Android 17. Did you get get any reports about this on v2.20?
eingeryn wrote: Fri Sep 11, 2026 6:13 pm Nice! I've been thinking of trying to vibe code DTC reading and deleting as I drive an old Subaru which is well known of having frequent P0420 error and disabling cruise control. Your example would really help me to start :D
In the latest version, it will be possible to adjust the colors, gamma and contrast in rendering post-processing. This will allow the image to better match the display panel.
What exact issue with audio focus are you experiencing in your setup? If you describe the problem and your setup in detail, we can try to reproduce the issue on our end.
delos23
Post by delos23 »
viewtopic.php?t=311
viewtopic.php?t=346
I've been checking daily since you posted this, I'm excited to see the DTC example.
I'm waiting too. Is there a function to change the background color from brown to other colors? I like it black or some gradient or something else
