Recommended hardware for a reverse camera
0lexy_the_cutie0
I was wondering if anyone could recommend a reverse camera to be used with hudiy if it is needed i have it running on a Pi5 8 gig version in a 2008 Ford Expedition XLT. Thank you in Advance.
- Contact:
Re: Recommended hardware for a reverse camera
if you want to use a cvbs reverse camera you can check out my recent cvbs to usb aliexpress pcbs tests:
viewtopic.php?p=1659#p1659
If you'd rather avoid adapters, there are also USB cameras that are directly compatible, though they tend to be more expensive and the selection is more limited. In a 2008 Ford Expedition, installation is straightforward as long as you have a 12V power source accessible near the reverse light.
