Update to version 1.24 (Bookworm) and 2.20 (Trixie) is already available
We are happy to announce that Hudiy 1.24/2.20 is now available. You can find the release highlights below:
Audio Focus
We improved volume ducking smoothness (navigation guidance and notifications) in audio focus.
Android Auto
We improved connection stability for the latest version of Android Auto.
Re: Update to version 1.24 (Bookworm) and 2.20 (Trixie) is already available
The boot seems very classic where we are still getting some flashes of Debian desktop screen. Is there plans to to remove those flashes and make it seem less like splash then Hudiy UI? No flashes of other background graphic.
wkl3968 wrote: Fri Aug 07, 2026 4:49 am The boot seems very classic where we are still getting some flashes of Debian desktop screen. Is there plans to to remove those flashes and make it seem less like splash then Hudiy UI? No flashes of other background graphic.
Please check the solution from this post viewtopic.php?p=491#p491
I'm trying to detect the Android Auto navigation audio start and end so that I can channel the audio to specific channels. How can I do this? So far navigation audio is mixed with media playback and hence I cannot detect it. I can detect the Google assistant. Need some guidance here
