Most probably you need to enable upmix feature in the PipeWire: viewtopic.php?p=1442#p1442
Also it might be needed to set proper volumeSinkName in main_configuration.json https://github.com/wiboma/hudiy/blob/ma ... n.md#sound
Hudiy detects number of channels based on sink information provided by the PipeWire.
https://github.com/wiboma/hudiy/blob/ma ... E.md#audio
HifiBerry DAC8x
Re: HifiBerry DAC8x
it is working now after I tried a freshly setup Trixie with Hifiberry DAC8x. I'm not sure if my earlier Bookworm has too many qpwgraph file interrupted the setup. anyway, will try out if it works. here is what I did:
Driver: Add dtoverlay=hifiberry-dac8x to /boot/firmware/config.txt to enable the DAC8x.
sudo apt install alsa-utils
# For PipeWire setup
sudo apt install pipewire-audio-client-libraries pipewire-pulse wireplumber
Create: /etc/pipewire/pipewire.conf.d/99-hifiberry-dac8x.conf
copy these"
context.objects = [
{ factory = adapter
args = {
factory.name = api.alsa.pcm.sink
node.name = "DAC8x"
node.description = "DAC8x"
api.alsa.path = "hw:sndrpihifiberry"
audio.channels = 8
audio.format = "S32LE" # Or S24LE
audio.rate = 48000
restart Pi. go to desktop mode and right click the audio icon --> device profile --> enable Pro Audio.
then go to qpwgraph to remap the audio links as shown.
then in the hudiy_startup.sh: add this
qpwgraph --minimized --activated --exclusive saved_routing.qpwgraph &
copy these"
context.objects = [
{ factory = adapter
args = {
node.name = "DAC8x"
audio.channels = 8
audio.rate = 48000
- Screenshot 2026-04-17 163518.png (262.75 KiB) Viewed 269 times
Re: HifiBerry DAC8x
I don't think it is because of the DAC8x issue somehow I get this udev thingy notice after I plug in my phone running Android Auto. I remember I don't have such during my early trial of Hudiy. however I get this a lot in OpenAuto Pro.
- Screenshot 2026-04-17 165713.png (21.08 KiB) Viewed 267 times
Re: HifiBerry DAC8x
This popup comes from pcmanfm (Raspberry PI file manager). Pcmanfm tries to mount connected USB device as an MTP drive. You can disable it in pcmanfm settings.
viewtopic.php?p=570#p570
Re: HifiBerry DAC8x
Now I'm trying out the Hifiberry DAC8x and ADC8x. It seems working too. I need to get a good mic with preamp to make it work.
Re: HifiBerry DAC8x
I have learned a lot recently. I have made DAC8x and ADC8x working. Custom pipewire setup. I use multiple custom mics to get beamforming and combined with CamillaDSP. It is getting seriously fun.
