Dashboard Widget: CPU Monitor
Re: Dashboard Widget: CPU Monitor
Thank you very much appreciate the help I got the widget to come on the dash board but the values are blank
Hi guys, thought I'd share some custom enhanced widgets for CPU Monitoring
Take note this has been done on Raspberry Pi 5 not sure if works on Pi 3 and 4?
Autyzmiasty
This new script with voltage and amps still doesn’t work for me, lol. At first it didn’t show volts, memory usage, or amps at all — I figured out why: the frontend was expecting different data than what the backend was sending. After fixing that, CPU voltage for example shows 1V and 0A.
