Waveshare orientation hdmi/ touch input
Sambolini94
Post by Sambolini94 »
Hi all,
I've googled this and tired multiple ways but just lost on how to adjust the orientation on my hdmi waveshare screen!
I'm running Pi OS Trixie on my Pi4 8gb with CarPiHat.
- My screen has USB-C power direct from HAT 5v output...
- USB-C to USB-A touch input
- HDMI video.
The screen naturally displays a specific orientation where the ports are the wrong way up so I have turned the screen 180 degrees so they come out the bottom of the screen and therefore the display and touch input needs flipping 180 degrees.
Anyway able to assist here.
Kr,
Sam
Re: Waveshare orientation hdmi/ touch input
Did you try to use Screen Configuration Tool in Control Centre? One of the screens we use for testing is the Pi Touch Display II which has a portrait orientation by default. After changing the orientation in the Screen Configuration Tool, the touch panel is also automatically mapped to that orientation.
Sambolini94
I'm sure I have tried that and it didn't seem to work but I'm going to do a fresh install of Pi OS Trixie and Hudiy and will try that again. If it doesn't is screen orientation both for hdmi outputs and touch input OS level or driver specific?
Sambolini94 wrote: Sun Feb 22, 2026 10:00 pm Hi,
It is specific for the window compositor actually. The default window compositor for both Raspberry Pi OS Bookworm and Trixie is labwc on Wayland. As far as we know, labwc uses libinput to communicate with input devices like touchscreens.
https://labwc.github.io/labwc-config.5.html#touch
https://labwc.github.io/labwc-config.5.html#libinput
https://labwc.github.io/labwc-config.5. ... tionmatrix
Configuration file is located in $HOME/.config/labwc/rc.xml (default path for Raspberry Pi OS).
