Splash logo
Splash logo
How do I replace the Hudiy boot splash image with a custom logo. i want to use a Custom GMC logo so it matches my truck
Re: Splash logo
The splash program is responsible for showing the logo when Hudiy starts. Using the --logo command-line argument you can set the path to your own logo.
On our GitHub you can find more details about the splash program: https://github.com/wiboma/hudiy/blob/ma ... .md#splash
Re: Splash logo
Can you please provide an example of this "--logo" command being used? The information on the github isn't exactly helpful, as it just states a general usage.hudiy wrote: Wed Feb 18, 2026 1:16 pm The splash program is responsible for showing the logo when Hudiy starts. Using the --logo command-line argument you can set the path to your own logo.
Re: Splash logo
--logo is a command-line argument for the splash application that launches Hudiy. The splash application is executed from $HOME/.hudiy/share/hudiy_run.sh via line:TheTHM wrote: Wed Sep 02, 2026 6:47 pmCan you please provide an example of this "--logo" command being used? The information on the github isn't exactly helpful, as it just states a general usage.hudiy wrote: Wed Feb 18, 2026 1:16 pm The splash program is responsible for showing the logo when Hudiy starts. Using the --logo command-line argument you can set the path to your own logo.
$HOME/.hudiy/share/splash $HOME/.hudiy/share/hudiy_startup.shCode: Select all
$HOME/.hudiy/share/splash --logo /home/pi/Pictures/logo.png $HOME/.hudiy/share/hudiy_startup.shHudiy Team
Re: Splash logo
Thank you for your fast response.
This is what I'm seeing when I run this command.
"qt.qpa.xcb: could not connect to display
qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: wayland, eglfs, minimal, offscreen, minimalegl, xcb, linuxfb, vkkhrdisplay, wayland-egl.
Aborted"
Any ideas on how to fix this? I'm feeling like an idiot, haha! I am running this on a Pi5. Tried to run the command on the Pi desktop without any luck as well.
***Update***
Looks like it just took trying it about 10 times! Thanks for your help with this.
Aborted"
***Update***
Re: Splash logo
This command should not be run standalone. If you want to run Hudiy manually, use the command $HOME/.hudiy/share/hudiy_run.sh (and add --logo there to $HOME/.hudiy/share/splash $HOME/.hudiy/share/hudiy_startup.sh line)
To run Hudiy via SSH, you must export XDG_RUNTIME_DIR and WAYLAND_DISPLAY before execution.
export XDG_RUNTIME_DIR="/run/user/$(id -u)"
export WAYLAND_DISPLAY=wayland-0
Re: Splash logo
So, to spell it out for idiots like myself...
Add the --logo command to line 8 of hudiy_run.sh
**EXAMPLE**
source "$HOME/.hudiy/share/rpi_lib.sh"
export LD_LIBRARY_PATH=$HOME/.hudiy/share/:$LD_LIBRARY_PATH
if [[ "$CURRENT_TARGET" == "$TARGET_GUI" ]]; then
$HOME/.hudiy/share/splash --logo /home/USERNAME/Pictures/YOUR_LOGO.jpg $HOME/.hudiy/share/hudiy_startup.sh
else
export QT_QPA_PLATFORM=eglfs
export QT_QPA_EVDEV_KEYBOARD_PARAMETERS=grab=1
export QT_QPA_EGLFS_NO_LIBINPUT=1
if [[ "$CURRENT_MODEL" == *"$PI5_MODEL"* ]] || [[ "$CURRENT_MODEL" == *"$CM5_MODEL"* ]]; then
export QT_QPA_EGLFS_KMS_CONFIG=$HOME/.hudiy/share/eglfs_pi5.json
fi
fi
**EXAMPLE**
else
fi
fi
