RetroPie uninstall
k.s.deviate
RetroPie uninstall
Fantastic, thank you. Slightly of topic, but i had retropie installed and decided i wanted to change directions. I uninstalled it and now AA loads a black screen. it seems to register touches and it plays audio and is communicating with the hudiy now playing. I'm wondering if by uninstalling retropie some packages or files that were present before the install were removed. Is there a way i can check to see if the required files for AA are present or if i can force an update of the same version sort of like a dirty flash?
Re: Simple Visualizer Mod
Hudiy uses hardware acceleration to render projections. Based on the RetroPie documentation, it has strong dependencies on things like Mesa (the graphics driver) and the entire video stack. It’s possible that the uninstallation messed something up in mentioned components. If you don’t want to reinstall the whole OS, you can back up your configuration (copy the $HOME/.hudiy/share/config directory somewhere else), then run the installer and the updater again to update Hudiy to the latest version. After that you can restore your configuration by copying it back to $HOME/.hudiy/share/config.
k.s.deviate
I completely reinstalled Trixie and Hudiy. Hudiy wont load at all, here is .xsession-errors. the splash screen loops and then kicks me out to the desktop.
Xsession: X session started for hudiy at Wed Jan 21 03:05:18 PM PST 2026
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
xrdb: Can't open display ''
xhost: unable to open display ""
dbus-update-activation-environment: setting USER=hudiy
dbus-update-activation-environment: setting LANGUAGE=en_US.UTF-8
dbus-update-activation-environment: setting TEXTDOMAIN=pam_chksshpwd
dbus-update-activation-environment: setting XDG_SESSION_TYPE=wayland
dbus-update-activation-environment: setting HOME=/home/hudiy
dbus-update-activation-environment: setting DESKTOP_SESSION=rpd-labwc
dbus-update-activation-environment: setting LOGNAME=hudiy
dbus-update-activation-environment: setting XDG_SESSION_CLASS=user
dbus-update-activation-environment: setting PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dbus-update-activation-environment: setting LANG=en_US.UTF-8
dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=rpd-labwc
dbus-update-activation-environment: setting XDG_GREETER_DATA_DIR=/var/lib/lightdm/data/hudiy
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting GDMSESSION=rpd-labwc
dbus-update-activation-environment: setting NO_AT_BRIDGE=1
dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
dbus-update-activation-environment: setting LC_ALL=en_US.UTF-8
dbus-update-activation-environment: setting PWD=/home/hudiy
00:00:03.387 [ERROR] [backend/drm/util.c:65] Failed to parse EDID
applying profile '<anonymous at line 1, col 9>'
applying profile output 'DSI-1' on connected head 'DSI-1'
configuration for profile '<anonymous at line 1, col 9>' applied
pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
Try `pgrep -f' option to match against the complete command line.
(polkit-mate-authentication-agent-1:1219): GLib-CRITICAL **: 15:05:24.504: g_variant_new_string: assertion 'string != NULL' failed
(polkit-mate-authentication-agent-1:1219): polkit-mate-1-WARNING **: 15:05:24.505: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
** (squeekboard:1246): WARNING **: 15:05:24.790: Could not register to session manager: Cannot invoke method; proxy is for the well-known name org.gnome.SessionManager without an owner, and proxy was constructed with the G_DBUS_PROXY_FLAGS_DO_NOT_AUTO_START flag
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::SystemPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::ToolButtonPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::ButtonPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::CheckBoxPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::RadioButtonPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::HeaderPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::ItemViewPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::MessageBoxLabelPelette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::TabBarPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::LabelPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::GroupBoxPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::MenuPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::MenuBarPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::TextEditPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::TextLineEditPalette
virtual const QPalette* Qt6CTPlatformTheme::palette(QPlatformTheme::Palette) const QPlatformTheme::ToolTipPalette
virtual QVariant Qt6CTPlatformTheme::themeHint(QPlatformTheme::ThemeHint) const
** (wf-panel-pi:1242): WARNING **: 15:05:26.484: init context: err:6 Connection refused
** Message: 15:05:26.552: batt: battery 0 not found
** Message: 15:05:27.048: up: Checking for updates
** Message: 15:05:31.726: up: Cache updated - comparing versions
** Message: 15:05:39.618: up: Check complete - no updates available
(rpcc:5981): Gdk-WARNING **: 15:10:17.883: Tried to map a popup with a non-top most parent
reloading config
reloading config
(pcmanfm:1244): Gdk-CRITICAL **: 15:11:23.600: gdk_window_get_device_position_double: assertion 'GDK_IS_DEVICE (device)' failed
(pcmanfm:1244): Gdk-CRITICAL **: 15:11:23.750: gdk_window_get_device_position_double: assertion 'GDK_IS_DEVICE (device)' failed
(pcmanfm:1244): Gdk-CRITICAL **: 15:11:23.900: gdk_window_get_device_position_double: assertion 'GDK_IS_DEVICE (device)' failed
(pcmanfm:1244): Gdk-CRITICAL **: 15:11:24.050: gdk_window_get_device_position_double: assertion 'GDK_IS_DEVICE (device)' failed
Info: Loaded layout Path: "/usr/share/misc/squeekboard/keyboards/us_wide.yaml"
Info: Loaded layout Path: "/usr/share/misc/squeekboard/keyboards/terminal/us_wide.yaml"
Re: RetroPie uninstall
Please provide the output of these commands:
ls -lah $HOME/.hudiy
ls -lah $HOME/.hudiy/share
ls -lah $HOME/.hudiy/share/config
ls -lah $HOME/.hudiy/cache/
pactl list sinks
pactl list sources
pactl list sinks
pactl list sources
